Just used an MSR Hubba NX. The fly sits high, there’s a vent and you can half roll up the entry side. There was little to no condensation on the 5 nights I’ve had in it in variously wind, rain and still /clammy.
Used a Telemark 1 last year…. If you have to batten the tent down that can generate a fair amount of condensation. If you have a breeze it helps. If you can leave the outer door open it vastly improves things.
Before that I used an Atko. It has vents both ends. If you use them it cuts condensation down considerably- if you don’t then you get quite a lot.
Like everyone else says- design…. And venting
