I’m kinda new to this air sprung malarkey having ridden a LT hardtail with a coil fork since a long time.
So as I understand it if I want my fork or shock to not give up the travel so easy I can either increase the air pressure or add spacers.
I’m running my fork with ~20% sag and the shock with 25-30%.
I find the fork (Fox 36 RC2) a little too soft and it gives up more travel than I would expect on relatively small drops (comparing it to my coil Lyrik). The same can be said for the shock (Float X Evol). I’m surprised that I am using most of the travel on relatively tame trails or drops that wouldn’t have caused me any drama on the hardtail.
I would like a little more reserve with both the fork and shock.
I’ve tried increasing pressures, but I then feel perched on the bike and I’m not sure running at excessively high pressures is the right solution.
I see that spacers come in various sizes. Is the size I need dependent on my weight?
How easy are they to install?
Yours, Confused
