Home Forums Bike Forum Tell me about… Rohloffs
Viewing 40 posts - 41 through 80 (of 98 total)
  • Tell me about… Rohloffs
  • simons_nicolai-uk
    What forks do you run ? Lead cast lowers ?
    Bombers 🙂
    Just as a quick sample though –
    On-one rigid CroMo fork – 1200g
    A set of Fox Float 32’s was about 1700g the last time I looked.
    gofasterstripes
    The alfine 8 is a far superior ride use mine almost daily.
    Conversely my Rohloff has around 10,000km on it and has never missed a beat*, whereas my Alfine 8 might have done 200k and it’s full of rusty water in a Madison service center somewhere right now.
    I suspect it is more suited to touring though, it is possible to “jam the synchromesh” and get stuck between gears, as well as forcing you through gear 14 for every shift. Both of these are only problems if you’re desperately mashing the pedals at the same time as cranking the shifter all the way around. It is also pretty weighty. TBH though, if you’re dropping £1k on a hub, buy a top end crank set and wheel components and you’ll likely come out pretty good for weight.
    I will never tour on anything else again.
    *Except when I bust it’s oil seal wrapping a bungee cord around it at 30km/h – but:
    wait for it…..
    They fixed it for free. In Australia. In 3 days.
    trail_rat
    My bike was 24lbs all in . Still rode like a dog due to the weight in the back wheel…same bike with a pro 2 ss in the rear was much better to ride… Skippy light and surged forward
    Interesting how some peoples perceptions are different. In its original thorn frame it felt like i was riding my old downhill bike just with a steeper head angle
    Might go dig mine out the back of the garage and throw it at my bike again and retry it. ( wasnt for lack of trying , mines used to commute and its done a few solo puffers both undr me and my mate – where ill admit it never missed a beat, it just amplified every bump.
    My alfines got 5000km on it i opened it once to find it sparklingly clean inside so put it back together without disturbing it and carried on.
    jes
    Oil leaks – my oldest one needs a seal change but it must be over 7 years old. (Is this still a back to Germany job or can Ison do it in the UK?).
    Simon, I purchased the tool and seals from SJS cycle and did it myself.
    Sprocket removal tool also required.
    If your Midlands based I would be happy to do the seal change for you.
    bencooper
    Ison? Heck, I can do that here in Glasgow 😉
    The paper gaskets can be swapped in 5 minutes with only a Torx wrench, the lip seals need a special Rohloff tool which good dealers will have.
    ir_bandito
    I’ve had a ‘hoff for nearly 6 years now, bought secondhand off here.
    Its been back to the factory for new bearings twice, fixed for free and a letter of apology that it had failed! I think I’ve discovered the source of the failure too -the wheel wasn’t dished correctly and I was aligning the sliding dropouts by getting the rim central between the chainstays, effecitvly setting it at an angle. Once I fixed the wheelbuild, I’ve had no more bearing problems.
    I love it. The stationary gear changing is brilliant, I’ve got used to the weight off the back and I don’t notice the drag.
    I do want to try a Pinion though.
    simons_nicolai-uk
    Paper Gaskets I’d done but I think this one now needs the lip seals doing.
    Ah – interesting. I’d not seen a tool or seals for sale on Ison’s trade pricelist last time I looked(some time back) so assumed it was something Rohloff insisted on doing at the factory (like fitting Gates sprockets for example).
    simons_nicolai-uk
    Ah – tool still doesn’t show on Ison’s site but SJS have them. Not a bad price as these things go.
    I was kind of right about it being a back to the factory job – “Only newer hub seals with an outer metal ring (Serial No. 25400 onwards) can be replaced …using the tool”
    The hub that needs doing is 27712 so only just in the DIY range but I think it’s the oldest of ours.
    http://www.rohloff.de/en/technology/workshop/tools/hub_seal_press_in_tool/index.html
    munrobiker
    I ran one for 3 years and switched back to regular drivetrains about 3.5 years ago.
    They definitely have a place- if you do longer rides on a hardtail that is light in the first place they are great as they reduce maintenance (a bit- the cables they come with are a liability with the liner prone to being pulled into the shifter, making shifting almost impossible) and are generally unnoticeable. I think if your bike weighs about 24lbs in the first place you’ve not much to lose.
    I fell out of love with it for a number of reasons, including-
    – Wheel removal is a bit of a faff with the box having to be removed all the time. Not the end of the world though.
    – The extra weight if you ride a lot of technical trails on a hefty all mountain bike (I ran it on an Evil Sovereign and weight with the Rohloff was about 33lbs, when I swapped to a regular drivetrain it was 29lbs) the extra weight pushes the bike weight up to an uncomfortable level, making rides more difficult especially when combined with…
    -…the extra drag. If you ride a lot of steep hills you’ll be in the 1-7 gears a lot, where the drag is. It is noticeable and can be demoralizing. The extra efficiency of a regular drivetrain is definitely noticeable.
    In the end, lower weight and less drag were the main reasons I ditched it and I’ve not looked back. I rode with another guy who had one and his has also gone in favour of a 1×10 drivetrain.
    If you do the bulk of your riding in a place that gets muddy and has more rolling hills or flat terrain and your bike is a decent weight and can live with £50 oil changes plus cables every year (I found cables last just as long as with a regular drivetrain) and the upfront cost then go for it.
    I also suffered from random bearing failures similar to the poster above.
    darkcyan
    I bought one and wanted to love it but i hated it – the drag was far more than on a standard bike – ok it was new 2000 miles etc etc but it really felt bad – like pulling a sack of potatoes. Just don’t get it!
    Gave up in the end.
    Now here’s the thing – I run 1×10 now (SLX) which costs me about about £50.00 to change over once a year (cassette, chain, front ring). Runs perfectly in the mud, great efficiency, no problem at all and works much better.
    No brainer!
    DC
    simons_nicolai-uk
    I fully understand that some people really don’t like Rohloff’s and I understand why but always surprised by the misinformation –
    £50 oil changes
    £50 buys you oil for a lifetime. An oil change kit is £17[/url] rrp but you can re-use the syringe and buy the oil cheaper in bulk (It looks like you can buy 250ml quantities rather than litres now)
    ratherbeintobago
    @orangeboy – have you routed the shifter cables along with the back brake hose?
    orangeboy
    Yep just cable tied the whole lot together but the bend is a little tighter than I would like but don’t notice when I’m riding
    MrH
    Mine’s 14 years old and working fine. My mates don’t drop me on the climbs but I don’t think it would be an advantage in an XC race. Trail riding i dont notice the difference. One of the main benefits is being able to change gear without turning the cranks – like when you drop down a steep decent and are met with a sudden incline. No mashing and crunching of sprockets.
    rosscopeco
    I’ve got 2, the first one being circa 9 years old and the second is about 6 years old.
    bencooper: Can you remember when I bought them?
    1 of them was back to the factory last year for gear slippage issues and got repaired FOC. The other one has run without a hitch…other than a few drops of oil which was easily resolved with new gaskets.
    Both are now on HT’s. One on a Cotic Solaris 29er with Paragon swinging dropouts and the other on a On One inbred with horizontal dropouts. Both are used across all types of trails but mostly almost daily on techy rocky / rooty trails.
    The first hub was originally used almost everyday (inc winter) for commuting on a 18 mile round trip across a mixture of trails / roads and most weekends for thrashing around local trails. For those of you who commute through traffic you’ll know that traffic dirt / film is far worse on a bike than good clean mud. With the old XT system, if I didn’t give it some TLC every weekend it would jam by day 8 or 9. Now I never have to do anything other than hose down the bike and give the chain a wee wipe with a dry lub once it’s dry. It’s just something I never have to think about now.
    I’ve competed in several 50+ mile off road races through some of the best (worst) terrain Scotland has and I’ve stopped counting the number of other competitors who who are cursing their fancy XTR / X0 systems that can’t shift properly because of the mud! I did the WHW over 2 days last year without a hitch.
    On balance I usually change the cables out every 2 years or so and carry out a 6 monthly oil change as opposed to waiting the full year.
    As you can tell I’m a big fan but here’s a few thoughts on some of the weaknesses etc
    Noise: Yes, it does make a little whirring noise in gears 5 – 7 but if you compare that to a normal system when you try and change gear quickly or when it’s full of mud, there’s no comparison!
    Weight: It’s a little on the heavy side but let’s be honest here, we’ve all spent time and money shaving grams off our bikes and then put on 5lbs over the xmas hols!
    Cost: It’s expensive and I spent ages making my mind up before I finally took the plunge but it’s more than paid for itself in terms of ease of use, reliability and peace of mind on the trail.
    I’ll never go back to the old way as they are the best bike related investment I’ve made.
    woodsman
    I use a metal braided outer brake cable – available from CRC, and xtr inner gear wires. I find this combo the most durable (18mtns-2years) and the smoothest.
    I run the hub on a Thorn 853 Enduro hard tail, and the whole thing comes in at 30 pounds or a fraction under. I have had it about 28 but it wasn’t durable. It has a place in the winter mainly, and also the summer – I used to run it all year round. But, my geared (xtr) hard tail is so much quicker, or I think so after a winter of riding the Thorn I always feel I have a few months fitness advantage from doing so. FWIW I can’t recall ever being dropped on a climb riding the Rohloff’d Thorn – maybe my memory is bad or I ride with slow people..
    bencooper
    Nope, but I think somewhere there’s a list of serial numbers and year of manufacture, could look it up if you’re interested.
    ratherbeintobago
    Next daft question: what cranks, and how easy is it to get the chain line right?
    bencooper
    Any cranks you like, and pretty simple – usually just lining up with the big ring works fine.
    Chain line is over-rated anyway.
    orangeboy
    Personaly I use rs7 or older xt hollowtec as I like internal bb
    But does not need to be anything special
    bencooper
    Looking for something else, I found the list of serial numbers:
    000000 – 000400 1998
    000401 – 002700 1999
    002701 – 006500 2000
    006501 – 012000 2001
    012001 – 018800 2002
    018801 – 027700 2003
    027001 – 038500 2004
    038501 – 050049 2005
    050050 – 065000 2006
    065001 – 081600 2007
    080601 – 100000 2008
    100001 – 115900 2009
    115901 – 135800 2010
    135801 – 153000 2011
    153001 – 171000 2012
    gofasterstripes
    I’ve just heard back – my Alfine is trashed.
    trail_rat
    Nice one ben , mines is 2005 then number 50039
    ir_bandito
    My cable-routing detail:
    Silver braided Jagwire brake outer into v-brake noodles, with Jagwire gear inners. I’ve got another pair of v-brake noodles at the shifter end too to get rid of the silly big cable loop. Works a treat and keeps it tidy.
    Sven
    I rode bikes with derailleurs for 15 years, then a Rohloff-equipped bike (in fact two or three frames worth) for 9 years, and both over the last two years (not at the same time :). There may be disadvantages to internal hub gears, but perceived drag, and weight and its distribution are not really amongst them, currently wheel removal due to the horizontal dropouts annoys me more…
    Half a pound more at the rear? People who now run 1×10 don’t complain that suddenly the weight distribution of their bikes changed as they lost front derailleur and chainrings. Also, the weight is thankfully in the hub and not further away, a heavy rim makes a bigger difference (to acceleration). Drag? Some friends still believe I have a little eMotor in there, and I am not that fast. I also think that a super-tacky Evo triple-Nano compound stick-to-rocks tyre creates more drag than a Rohloff, if the latter does at all.
    The only reason why I changed chainrings (and sprockets) in the last few years was to try slightly higher/lower gears, and change ‘the looks’, wear is hardly an issue. Which is the main point, with a few oil changes over the years, one return journey to Rohloff for a service, and no maintanance other than oiling the chain even after very muddy rides, I can spend more time actually riding my bike rather than servicing it, and that’s what counts most to me.
    Gratuitous pic of my latest build and cable routing (since ir_b posted his):
    molgrips
    If I got one it would be to create a mud proof drivetrain, with a belt.
    nicko74
    MidlandTrailQuestGraham did exactly that. He also put a Lefty on his, and possibly gone 29er, in an effort to outniche everyone else… 😉
    woffle
    I rode a Rohloff equipped Airnimal for about 12,000 miles. Only annual oil changes and one set of cables in that time.
    avdave2
    The guy on the Rohloff stand at Handmade showed me a rear gates carrier that had come of a Rohloff. You could have shaved with it it was that worn and sharp. Gates now supply steel carriers as a result of wear. Combine that with a snubber and the extra weight to both stiffen and allow the rear triangle to split and there are no weight savings over a chain. The belts are expensive and have to be handled carefully and can break in use if stones get picked up with mud into the drivechain. I believe MTG has broken at least one belt. I only spend 2 minutes a week on my chain in the worst winter conditions and it’s used off road to get me to work every day. The drivechains already filthy so I can’t see a single advantage to the belt off road.
    woodsman
    2005 here too according to Ben’s year/part numbers list.
    molgrips
    The reason I want a belt is because I hate the thought of all that mud grnding my chain away. It’s not about cleaning as such, more the destruction of a part.
    I might install a chain guard though if I was using Rohloff, to keep it clean 🙂
    avdave2
    I’ve had 4 years from a chain without it being ground away. The first cheap 9 speed SRAM one lasted over 3 and I only changed that because I thought I should. It would almost certainly have gone on a lot longer. I’m sure anything that will wear a chain will wear a belt. I damaged my year old chain recently and replaced it with another £10 kmc one keeping the same chainring and sprocket. It was a little noisier for the first few miles but is running perfectly now. It turned out that the original chain was ok it was the link that I’d used for the life of 2 chains that was on its way out.
    ir_bandito
    Did I mention I’ve got a belt drive ss too? One day I’ll merge them together….
    avdave2
    molgrips it looks like MTG thinks I may be right. Thread here
    molgrips
    Bah.. Shame that. My search continues. I still thing I would like to fab some kind of chain guard if I had a hub gear.
    trail_rat
    i think id just buy and fit a hebie chainglider if i was looking for a solution to a problem that doesnt really exist.
    avdave2
    I can see the point of a chainglider on the road – even a belt drive but come on half the fun of a mountain bike is being a kid again and getting covered in mud.
    molgrips
    Having my chain covered in crap is a problem. It causes shitloads of wear.
    munrobiker
    In response to simon_nicolai’s post, my details about 50 quid oil changes is not misinformation. That is how much they cost at the dealer I got mine from. I didn’t want to do them myself, regardless of how easy it is perceived to be.
    bencooper
    I’ll charge you £100 to pump up your tyres if you like?
    It’s not really fair to blame Rohloff because you were stung by a shop 😉
The topic ‘Tell me about… Rohloffs’ is closed to new replies.
