I pulled the damper apart, shims and all, greased everything, replaced the oil with genuine rockshox stuff of the correct weight, set the IFP depth properly and pumped the IFP chamber up to 500psi. That seems to have fixed it since I can now get full travel with the correct sag, and the shock is dramatically better – far more supple and responsive.
I think someone had done a home service and used heavier oil, as previously I had the rebound set on minimum and now it’s somewhere in the middle for the same damping effect. Too heavy oil would also explain not having been able to get full travel.
Up yours, singlespeedstu.
