Some of the Novatach (rebadged by superstar) hubs have a small 2mm grub screw in the middle you need to undo (and another next to the pawls you don’t)
If the free hub has “gone” it’s mostly likely either the pawls or bearings … when you take it apart and clean the free hub if the pawls are just sticking and you take them off, inspect and clean em you likely just fixed the problem. If it’s the bearings it’s another story but unless they had bad bearings in that shouldn’t really be the case.
My experience of Superstar is assembly can be variable. I have some Nano-X pedals that started clicking 3rd ride and after disassembly, cleaning and regressing are now fine… but they had been badly assembled and water and mud was getting in…
My wheels needed rebuilding… on the 1st ride I had a cm of wobble on the front (wasn’t using the rear) .. I just intentioned all the spokes and re-did the end of the build and they are now (many many rides on) working great and running true.
I could have warrantied either but the hassle of then having to be in to get them delivered back outweighs 10 mins on the pedal or an hour for both wheels…
