Might be worth checking eBay for an RSP Plummet dropper post. There are 2 versions but the cheaper one is the original mechanical one – you can tell which one that is because it has a rubber boot over the main shaft.
It’s mechanical – so essentially a big spring to return the post to full extension with a pin that locks into notches on the shaft to locate. TRhink it was 100mm travel with a top / middle / bottom setting.
I used one for a couple of years with no maintenance or mods and it just kept going. The standard lever was ok (push down on it rather than a 1x style) and it just worked.
It was a little clunky as that type of dropper would be, but it sounds a lot better than the t-mars. I recently sold it for £25 plus postage on eBay.
I never did it but I understand they are easy to strip and re-grease. Mine had got a little sticky towards the end because I wasn’t using it very much.
Not mine but there is one on eBay at the moment – clearly I can’t vouch for its condition!
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F123858644373
