Talk to me @big_scot_nanny 🙂
One of the reasons for putting my ICT frame up for sale was the limited options for fitting a 150mm dropper. So, I’d be interested to hear how you routed yours.
Also:
What is clearance like for 29+ on the rear?
Where did you get your wheels and what rims are you using?
With my usual fantastic timing I’ve just sold my Bluto, but I guess there are better options for a 29+ fork anyway.
I’ve been 29+ curious for a while but wasn’t sure it would really work with the ICT. I don’t need masses of grip at the back. I’m happy running JJs on the rear even in winter, as long as I have something nice and sticky up front (currently a Bud).
NP
I drilled a ‘slot’, just a little wider than a cable outer and about 15mm long, about 10cm above the bottom bracket, just like this piccy (not my bike), and routed the cable up under the downtube. Not pretty, but it works, and a 170mm dropper just makes the bike even more fabulous. The trails come alive, man 😂
https://goo.gl/images/jgwPgx
Gobs of clearance for 29+, also on Bluto, even with DHF on which is truly mahoosive
My local LBS built them, Hope fat on the back, spare 150mm Salsa on teh front. Stand Hugo rims for piss easy tubeless.
I think 29+ works superbly on ICT. With 120mm blutos the seat angle feels a bit too slack, but the front end and general ride is fantastic.Bombproof, but faster than full fat.
