“nairnster
I don’t see how it would be any quicker than changing the whole ring on a cinch system.
Several small bolts to undo instead of just the cinch ring or whatever it’s called.”
You’ve got to take the crank off to change a cinch ring. Not that any of this is a real advantage or disadvantage tbh but it’s definitely going to be faster. The point of the spider isn’t reuse, it’s just to have less steel in it, the rest’s just spin.
Me, unless the prices crash and the parts availability changes I’ll be staying with alu but I think it’s a good intervention. SRAM and Raceface already do all-steel steel rings which makes a lot of sense but it’s about 100g heavier than an alu one and that’ll kill some people. Also you can only buy the RF one from bloody Activesport and I’d rather perform DIY dental surgery.
(it’s not just about outright lifespan; steel will keep the profiles nicer meaning better retention for longer. Same as my old deore steel rings used to shift a little bit less well than XT on day one, but by about day 50 they were still pristine while XT had lost its edge)
