Home Forums Bike Forum Stuck hollow tech II? Removal tips
Viewing 8 posts - 1 through 8 (of 8 total)
  • Stuck hollow tech II? Removal tips
  • makecoldplayhistory
    Just to check before I really start hammering (or hacksawing)…
    I removed the blank plug and then the plastic piece inside. I’ve inserted the shimano removal tool and then tried tightening it (RIP two screwdrivers) but it hasn’t budged.
    I’ve tried tapping with a flathead screwdriver between the crank and BB but nothing seems to have moved much.
    I’ve tapped a bit harder but still no real movement.
    Any ideas?
    Thanks in advance,
    2
    retrorick
    Doesn’t look like a Shimano hollow tech bb to me?
    Does it use a self extracting Allen key type bolt to remove the crank?
    1
    makecoldplayhistory
    It’s an M970.
    1
    makecoldplayhistory
    I’ve just realised that I shouldn’t have removed the large bolt from the non-drive side. The extraction tool worked extremely well!
    Bruce
    I think the procedure is to remove plastic ring. Leave the big alloy thing with a allen key hole. Screw in the tool, undo the big alloy thing with a allen key and it should pull the crank off.
    Bruce
    Grr too late🙂
    Rubber_Buccaneer
    Sounds like you’ve sussed it now, this video covers installation then removal though
    makecoldplayhistory
    Yep. Sussed now. Thanks all
