I’ve got a gas canister burner and have tested a patch, comes off nice and easily.
Before I kill myself with inhaling fumes as I’ve no idea how old the paint is underneath ( lead paint !?!?)
Is it safe ? well ventilated as it’s outside, do I need a mask ??
Once door is stripped
Sand the door
Undercoat
Paint colour of choice
Afair, lead paint won’t fume until over 600f? ish. So a hot air gun on a low setting outside would probably be okay. You should probably get a cartridge filter mask with a an organic vapour cartridge if you want to use heat, even if you are outside.
Better still use an environmentally friendly stripper with a N100 particukate mask.
I redo ours every few years. It was custom made from Pine and the knots are a PITA, knot sealer does bugger all and the sun cooks it and the oil lifts the paint.
So last year I stripped it with a hot air gun, then drilled out every single knot and filled the hole with two part expoxy and put knot sealer over that…
[url=https://flic.kr/p/2ewnbL4]Front door[/url] by Ben Freeman, on Flickr
[url=https://flic.kr/p/25iHCNc]Front door[/url] by Ben Freeman, on Flickr
[url=https://flic.kr/p/2ewnbKx]Front door[/url] by Ben Freeman, on Flickr
Then undercoat…
[url=https://flic.kr/p/25iHCUK]Front door[/url] by Ben Freeman, on Flickr
and gloss..
[url=https://flic.kr/p/2fQHb5A]Front door[/url] by Ben Freeman, on Flickr
Almost worked, didn’t quite get all of one knot and there is one spot which lifted over the summer…..
