Steel hardtail choice.
Hi I’ve been looking at changing my rocklobster frame with one with a slightly longer top tube and a more relaxed head angle as I find the rocklobster steering a little too quick for me.
(Already have a 120mm stem fitted)
Have narrowed my search down to three frames; all three frames seemed to be well liked on these forums, all three are sub 5lbs which was one of my criteria and all three have a longer top tube and more relaxed steering.
1) Genesis Latitude 4.7lbs £330
2) Sanderson Breath 4.6lbs £410
3) Cotic Soul 4.4lbs £500
These are the weights and the best prices I’ve found so far.
Not much in the weight and geometry but there is quite a large difference in prices.
And finally my questions.
1) How would people compare them?
2) Is the Cotic worth £170 more than the genesis?
The Cotic and the Genesis have very similar manufacturing and build quality, and the Sanderson apparently has slightly better build finish but are not manufactured using the latest techniques i.e. DBZ, double and triple butted etc.
Any advice suggestions in helping me make my mind up would be appreciated.
Thanks Jon
