Home Forums Chat Forum Stans 29er Crest tyre fit
Viewing 8 posts - 1 through 8 (of 8 total)
  • Stans 29er Crest tyre fit
  • drbob65
    Trying to change tyres on stans crest rims, fitting rocket rons, the fit is insanely tight, I gave up last night, put it down to it being cold, using the stans yellow tape, but with tubes, clearly there’s a trick, any ideas?
    nuke
    It comes up fairly often, try a search. Here’s a good one for starters…
    http://singletrackworld.com/forum/topic/is-actually-possible-to-get-a-tyre-on-ztr-crest-rim
    akira
    It does get easier with practice, at first I could barely get tyres on. Now with decent tyre levers, fairy liquid and pinching the beads as far as they can go into the centre if the rim its a pretty easy job.
    What tyres you using? Spray ground controls and onza ibex pretty tight, on one chunky slacker than an inappropriate comment in comparison.
    akira
    Grrrr!
    tlr
    Maxxis Ikons seem to go on easily enough
    drbob65
    I changed to Ikons and was able to put them on with my hands, so lesson learned
    weeksy
    It really is down to technique. Bit of moisture on the beads… bit of technique. I sold a pair of 29er wheels as i couldn’t get anything on them…. i now know, it wasn’t the wheels/tyres fault but all my own.
    http://singletrackworld.com/forum/topic/forum-etiquette-people-who-obviously-havent-read-the-question 😉
The topic ‘Stans 29er Crest tyre fit’ is closed to new replies.
