- This topic has 115 replies, 40 voices, and was last updated 10 years ago by dragon.
SRAM starting to kick off about thick/thin chainrings and Patent?
mickolasFree Member
I think they’re okay if they can show that their idea is original and they had it first.
dangerousbeansFree MemberAh, ok. I’m a bit wiser now.
*Draws pictures of thick/thin chainrings with a plus shape and write 3rd November 1982 on the bottom*
Untold riches, here I come.
MosesFull MemberSRAM applied for the patent before anyone else started making the parts. Yes, they can ask for retrospective licence fees & damages, just as Apple did to Samsung in the USA.
However they are not abusig their position. There are alternative chainsets available, just not with this particular feature. We don’t have to buy thich-thin rings, after all.
It is possible to patent a new application for old technology, in this case for lightweight bike chain drives, using the thick-thin principle. An example of this is the extension of drug patents from one disease to another indication (eg Botox, Viagra)
Even if they’re able to rein in the copy market now, the genie’s out- we know a little company in England can make rings that do the same job for £35, so even less people will be happy spending £70 for a SRAM one.
But it’s not about the manufacturing cost, it’s about the value to the user and the cost of the R&D. For instance, bringing a new drug to market costs up to a billion US$. The drug might only cost pennies to manufacture, pennies to market, but they have to get back those R&D costs somehow. That’s why prescription drugs cost so much and why patent protection is needed. Viagra, for instance, is just about to drop in price by 80% now it’s off patent in the UK. Its price will remain high in the US, and is dirt cheap in India where they don’t recognise IP so effectively. (They also have a habit of not making to a high purity, but that’s a different story)
So just because a UK company can charge £35 instead of £70 for a knock-off, is no reason for saying the higher price is not justified. The manufacturing price is a small part of the overall cost for originating products.
By the way, Sustrans’ part-time lawyer spent many years in patent law. He might be interested in some consultancy!
theflatboyFree MemberRick, while you’re here – any news on when gold rings will be available? Fancy cancelling the next run of black ones and doing a load of gold instead? 🙂
dangerousbeansFree MemberThat’s right Moses – piss on my chips, why don’t you. 🙁
HoratioHufnagelFree Memberhmm, I wonder what all the other bike companies are submitting patents for?
Shimano road STI’s with mechanical shifting and hydraulic brakes…
https://www.google.com/patents/US20130032000rickatworkscomponentsFree MemberMoses – i agree with a lot of your points.
And to comment on pricing – our rings will go upto £38.00 in the very near future.
Reasons why we are cheaper: The design of our ring does not incorperate hooked directional teeth and additional chamfers – Machining time = Money
The XX1 ring is thicker (material cost increase) and is threaded (time again) rather than using standard bolts. SRAM also has a vast supply chain to service – we dont. SRAM pricing seems quite fair usually.Gold – we have samples sitting here now, ready soon!
NorthwindFull MemberMoses – Member
It’s not just a knock-off though, is it? If the competitors were just making direct copies you’d have a sound point but that’s not the case as has already been covered.
theflatboyFree Memberrickatworkscomponents – Member
Good to hear. If you need a colour-specific test rider, let me know.
MosesFull MemberNorthwind, for knock-off I mean copying the key features. If the EPO decide that the key feature is the cross-section change, then if you copy that you may be infringing the patent. Non-functional aspects of the design are irrelevant.
If Works are confident in their design, I’m really pleased. I like to see UK-manufactured goods.richmarsFull MemberReasons why we are cheaper: The design of our ring does not incorperate hooked directional teeth and additional chamfers – Machining time = Money
If I was being really unkind, I would say, also because you don’t have to pay for R+D.
rickatworkscomponentsFree MemberIf I was being really unkind, I would say, also because you don’t have to pay for R+D.
Not entirey true but i agree not to the same level of expense.
NorthwindFull MemberJust thinking out loud but if the “cross” shape is a key feature then would just running another pass and adding an extra step or a bevel get around that?
Moses – Member
Sure, but your point was that SRAM have to recoup r&d while others don’t… But that’s only the case with a direct copy. Admittedly variations on a theme are cheaper to develop than totally new concepts (not that SRAM have produced a totally new concept), but competitors have come out with simpler designs that still work just as well- an improvement not just an analogue.
honourablegeorgeFull MemberRick – I see you’ve changed the website blurb to remove the “Inspiration taken from SRAM’s own XX1” line… probably for the best 🙂
Even if it’s not a direct copy, it’s still using someone else’s idea for your benefit. The variation may or may not be enough to avoid infringement, that’s for the lawyers to decide. The development may still take work, but the IP is imortant too.Another drug-related analogy: the patents on a particular drug are for the active chemical used. Patent busters and generic manufacturers still need to work out how to make that ingrdient, which may involve quite a bit of R&D. They still can’t sell the drug while its under patent, even tho they could patent the process used to make it.
rickatworkscomponentsFree MemberRick – I see you’ve changed the website blurb to remove the “Inspiration taken from SRAM’s own XX1” line…
Ah yes, though not on the advice of the forum – as i say we have been talking to people about the matter and that was the first point raised 😉
molgripsFree MemberAs I understand it, the US patent system lets you file any old thing, and relies on your competitors lawyers to come up with prior art.
With the UK and I think EU system the patent office does a prior art search and can refuse you.
Of course, but all that was specifically about R&D costs. And the fact remains it’s not SRAM’s idea.
unklehomeredFree MemberAnd the fact remains
it’s notit wasn’t SRAM’s idea first.May be a vital bit, it seems unlikely Sram look to the 1970s agriculture industry for inspiration. Yeah they may have seen it, may have had a similar idea mindependently, it does seem a bit like the Cat Flap, an obvious idea someone somewhere still had to think of.
Tricky. Certainly not as simple as it at first seems. Since SRAM are holding back their tech from the mass market formats, I hope the Works is sufficiently different not to be effected. At least until I get a few in…
coursemyhorseFree MemberA lot of people keep going on about R&D costs, and that SRAM may have spent a lot researching this and that this justifies the patent. Nobody has any information about how long they had been testing/making/researching this. It’s quite possible that someone came up with a design one morning and then later in the afternoon a CNC Mill knocked one out for testing which worked A1 instantly.
I’m not saying it’s not a good idea – it is – but it’s incredibly simple and is just one of those wierd ones where nobody has made it before as it’s almost too obvious. Just saying, I can’t see that this took years of R&D and millions of dollars investment.
thisisnotaspoonFree MemberSomeone mentioned the clutch thing erlier, that’s a perfect example of the patent system working as it should.
Shimano design and patent the ‘clutch’, patent it, and the patent tells the rest of the world how it works and gives shimano protection against people copying it.
SRAM then made something different/better.
Thus the patent system encouraged development of new technology and competition.
There are examples in other industries like petrochemicals, F1, NASA, and the military where companies deliberately don’t patent stuff as the idea is you have to share the knowlage of what it is you’re doing so they can go away and develop better stuff. In those industries they rely on the idea remaining secret from competitors (other licencors, teams, countries).
You could probably patent the Eurofighters controll software for example, but that would mean publishing all it’s details, putting a lot of Chinese spies out of work!
coursemyhorseFree MemberIt depends how the patent works. If it is strict, it may not allow ANY design which retains a chain solely by the tooth profile of the chain ring. That will leave no where for manufacturers to go and no other designs possible.
If they patent the specific X-Sync shape then that’s not so bad.
oscillatewildlyFree Memberif sram put a patent on this and get away with it then whats the biking world coming to?
shimano had a clutch mech first, no matter how you build it up whether different internals are used or what ever, the principal is the same, they ripped off shimano’s clutch mech, its as plain and simple as that
so SRAM can do one, hopefully it will get quashed and it wont come to fruition, but if it does i wont be buying a sram groupset, ill wait for shimano to come up with something the same but slightly different 😉
NorthwindFull Memberunklehomered – Member
Not as such but it’s reasonably likely someone says “How can we make a chain stay on better?” then checks old patents for inspiration/prior art. Not specifically farm machinery but “drivetrain” and “retention” or similiar.
But either way, it’s still not their idea, it’s Joe Q Farminventor’s. And tbh half the things in the patent just feel like fluff to try and create differentiation- the X shape frinstance isn’t some exciting breakthrough, it’s just the right shape to go in the gap. And other bits, we’ve seen competitors don’t bother with and it still works.
cookeaaFull MemberThe devil is always in the detail…
While you might not be able to patent a general engineering principle or concept already in the public domain, you can apply for a patent specific to an engineering application…
SRAMs Patent opens with:
This invention relates to chainrings, and more particularly, to a solitary chainring for use with a conventional chain in a bicycle drivetrain system including a bicycle crank.
while the 1979 patent opens with:
This invention relates generally to chain drives including sprockets and flexible chains employed therewith and, in particular, to the configuration and arrangement of the sprocket teeth.
SRAM are hedging their bets to a certain extent by applying for a very specific patent covering only the design of a bicycle chainring, rather than a “General” concept for application to sprockets used in “Chain drives”…
And skimming the two applications they are using a similar engineering principle for differing purposes, one is using it to improve chain retention on a bicycle, while the other is using it to accomodate missalignment of sprockets in agricultural machiinery…
It’s contentious TBH and SRAM’s patent app may yet not be granted, or could only be granted within the US and not apply internationally, as I believe is the case wit hthe “Horst link” / “FSR”…
I was always told (as an engineer at least) that patents are not there to completely exclude any possible competition, that they are there to give the patent holder a “head start”. To get their product to market first with a feature(s) that your competitors will have to spend more time and money to replicate, while engineering their way around the finer points of your patent, or they just approach you for a licencing agreement…
There are some facinating annecdotes relating to this sort of thing, like the fella who invented, intermitent/variable windscreen wipers for cars, patented the concept, then took it for show and tell round all the big car companies only for them to turn down his idea. He then made a killing, when a few years later, the same feature popped up on various cars infringing his patent… dunno how true that one is but it’s a nice story…
thisisnotaspoonFree Membershimano had a clutch mech first, no matter how you build it up whether different internals are used or what ever, the principal is the same, they ripped off shimano’s clutch mech, its as plain and simple as that
No, because internaly they are completely different (I’d go as far as saying the later, SRAM interpertation is better!).
Shimano uses a normal spring and adds a one way friction clutch to it.
SRAM presumably read the patent and figured a better idea was a massivelys tiff spring, and a lock to allow the mech to go slack.
Fake example:
company A patent asprin, company B develop paracetamol.You can’t patent ‘painkiller’, but you can patent a design for something that reduces pain, spurring others to come up with something better. You could actualy develop your copetitors product, then sell your inovation back to them (or licence theirs to enable you to sell it)!
oscillatewildlyFree Memberthisisnotaspoon – Member
Fake example:
yah i know what your saying, but the initial idea obviously came from shimano! sram may have tweaked it and made it better/better internals or what ever, but the idea in principal is the same and SRAM have exploited that
sram lets say have created this idea and are now not willing to let anyone else exploit it!
shimano laid down and didnt kick up a fuss as far as im aware about sram ripping their clutch idea off
shimano will do something better, they always do!
theflatboyFree MemberIf SRAM had infringed Shimano’s patent, Shimano would have “kicked off”. This is the whole point of patents, as already mentioned above – it’s a bargain with the state that you have protection of the technology as defined by the patent in exchange for making your innovation public and allowing others to understand and build on its principles.
In the clutch situation, Shimano still have protection for what was patented, it’s just SRAM came up with a different means to an arguably better end. But crucially, presumably, without infringing Shimano’s patent.
thisisnotaspoonFree Memberwhat theflatboy said,
Another less well known patent is shimano’s cassette, only shimano cassetts have the rings aligned perfectly so that if you do a multiple shift it does so smoothly, SRAM’s derails then re-engages. But look at some of the new SRAM road cassetts, they’ve got missing teeth to finaly get arround that patent.
oscillatewildlyFree Memberi know all that, im just saying though the ‘idea’ of the clutch mech was started from shimano, whether they patented it or not
so if the chainring is patented by sram, hopefully shimano can do the same and rob the idea/tweak it with their version – lets face it they wont be far behind with something up the sleeves, which doesnt infringe the so called patent!
NorthwindFull MemberOscillate Wildly – Member
I don’t think that’s necessarily true… Or at least, SRAM certainly had something in development long before Shimano went public with the clutch.
dragonFree MemberI doubt SRAM were looking into agriculture patents, as that farm one linked on page 1 of the thread, was referenced in a later patent by Simplex, which in turn has since been referenced by both Shimano and Campag. Hence, it’s safe to say this info was pretty well known in the cycle industry already. So it’ll be interesting to see if SRAM can make the patent stick.
The topic ‘SRAM starting to kick off about thick/thin chainrings and Patent?’ is closed to new replies.
