Hi,
Trying the famous Shimano 10 speed clutch mech with SRAM 9 spd shifter and cassette setup.
I have a 2005 SRAM Rocket 9 speed shifter, works great with a Shimano XT shadow 9 speed mech.
I just bought a Zee 10 speed mech, made the 6mm adaptor, but the leverage ratios are clearly well off.
From 9th to 8th will shift Ok just about, then every shift afterwards is clearly not moving anything like far enough, so 4 shifts up will just about move it 3 gears. So the shifter runs out of gears/shift and the mech has only moved up to around 3rd gear.
Either the shifter doesn’t move enough cable or the length of mech arm from pivot point to where the cable is clamped is too long.
What have I missed, does the Rocket shifter have different pull to X7/X9?
Help me Singletrackworld Kenobi, you’re my only hope. This is properly doing my head right in! ❓
