Yep like you guys that’s what makes it odder, I used to have a right bastard time getting them off when i first had them to the point I felt like I was gonna snap something
Now they tighten up to 50nm (torque wrench) and then I check make sure its as tight as can get and then I can now easily undo them, still have to put force through but they do come undone way easier than I remember which is odd
The threads look perfect to me and it all lines up fine
Preload it’s wound out all the way out then I tighten up the Crank to 50nm then do wind the preload in till it just about touches and takes out the play
Again all as normal as I’ve ever done without this happening
The threads look absolutely fine to me and there’s nothing odd or odd noises when they are correctly first installed again
Hmmmm
