Did you have to buy a new crank or reuse your existing one?
The groupset came with cranks. I could have reused the old ones, but the groupset was pretty good value and I wouldn’t have saved a lot if I had and they were battered to hell anyway.
Also does anyone know if you can use any chainring or does it have to be an eagle one?
As it happens, I swapped the stock (6mm 32t) ring from the GX Eagle groupset for a 34t boost chainline (3mm) version from Superstar. 12 speed compatible and seems nice and quiet to my ears:
https://www.superstarcomponents.com/en/raptor-chainring-sram-boost-direct-mount-narrow-wide.htm
It’s very odd that SRAM don’t offer a boost chainline version of the groupset, choosing instead to offer two fractionally different crank lengths instead, especially considering that the official SRAM chainrings aren’t very cheap and, in boost line at least, are quite hard to source.
What is a “swapout”
A straightforward “one groupset off, one groupset on” with as few other bits changed as possible (e.g. BB, hubs etc.). In my case, I replaced the shift cable too because, well, why wouldn’t you? 🙂
