Rear brake felt a bit spongy this morning and just thought it needed a bleed. Then noticed some fluid where the hose exits the chain stay. The hose kinked where it enters the frame at the top of the down tube. I’ve removed the hose and there were a few drops of (Dot) fluid inside the frame (2020 On One Whippet). The frame has a guide/insert for the hose but the leak was just before this so fluid could have gone around this.
I’ve removed the forks and flushed the frame through with a little water from the chain stay through to the head tube. Is there anything else I should do? Or not worry? I’ve not removed the BB as I’m sure it has a metal insert anyway.
