I was going to suggest a trials rim, too.
Also on the trials front. The width works fine with V’s no?
Yes, can confirm. Plenty of trial riders use / used Maguras but good V-brakes are fine too.
In the early (pre v-brake) days, Maguras were niche but way more powerful than anything else so trials riders used them and continued to do so after trials-specific Magura pads / brae-boosters / levers were made. Maguras just kind of ‘stuck’ although I personally never saw much benefit over decent v-brakes.
Re: practicalities of using v-brakes with wide rims. Depending on the pad, sometimes you’ll have to switch the pad spacing washers around to maintain an optimum ‘vertical’ position of the brake arms, otherwise they are splayed out too wide with slightly reduced power – and you might catch your ankles. But nothing major.
