Tyres are such a personal thing and the rim width vs tyre size makes a huge difference, as well as hardtail/full suss, terrain, surface type, and on and on and on!
I have run 29er DHR2 2.3 EXO 3c on 25 mm rims for 4 years but got fed up with carcass delamination and distortion long before the tread dies. So tried the wild enduro (magic-x2 front gum rear). And I love them for the same type of trails as the DHR2 but for my money the michelins go round corners better (huge well supported side knobs) but are slightly less good in gloopy mud (they are bigger). The michelin tyre magic-x compound is great when you are pushing it but doesn’t do much if you are just “out for a ride”. The gum-x is better for that.
I mentioned on another thread that I tried them on 25 and 30mm rims. On 25 the profile was nice, on 30 it squared off too much and didn’t like corners so much, I imagine that on 35mm they are shite. I’m trying to find the source but I recall Michelin recommending a 25mm rim with 30 as the max; as 25mm is rather narrow these days I can see why people give them indifferent reviews as they are being used at the design limit. Same for a DHR2, if you run 30mm rims you should probably use the WT format rather than standard otherwise the knobs will be in the “wrong” place.
