kayak of this parish? Always impressed by his creations.
Awww shucks 😊
will not entertain anything that isn’t solid wood.
Solid wood is lovely, but it’s not always the best material and there is a misconception that modern isn’t as good as old. Truth is, lots of old furniture is veneered onto lower grade timber and as such often cracks and splits. Modern substrates such as mdf and plywood are very stable and I’m sure would have been used if available back in the day.
Cost is an issue. Looking at a budget of about £500 to cover a two door design.
That’s going to be difficult to achieve I’m afraid.
Let’s put aside the materials for a second and imagine making and installing that.
Maybe 2-4 days to make a solid wood wardrobe and two doors if you make it well. A day to 2 days to fit, having read that it’s at the top of a house up a narrow stairwell and will need to be assembled in situ.
Then materials. Softwood maybe £100-200 though that’s probably conservative. Hardwood possibly £200-350. Hinges, catches, knobs, hanging rails etc, etc.
Let’s say 5 days total and very conservatively £250 materials and hardware. That’s only about £6 per hour.
Budget is starting to look a bit tight.
You may get a handyperson type willing to knock something up but you’ll Defo struggle for a bespoke item from a furniture maker for that I’m afraid.
Flatpack, compromise and making it fit is probably your best bet 👍
