I have a smart meter and solar.
I also have a generation meter on the solar install.
solar panels -> Inverter -> gen meter -> house -> smart meter -> grid
Basically if you use what you produce the meter does not tick up. A modern meter will never go down or backwards.
I am on a feed in tariff, I get paid 5p a KwH when I ring in the generation meter readings.
Electric costs 12p KwH to buy.
So you don’t want to be exporting any to the grid as it costs more to buy than sell. Especially if you have a DIY install that you will not be able to get a FiT on.
Also remember I get paid the FiT on everything I generate, even if I use it all….so i get paid for it, use and don’t pay for it….
Hence I also have a Solic200 solar diverter (£150), when the suns out the solic200 will divert any extra into my immersion heater for hot water. Meaning I burn less oil heating water each day.
If you have an ancient meter that will run backwards…. then lucky you, effectively you get to sell electricity for the same price as buying….but be aware enquiries as above from electric companies.
