- This topic has 109 replies, 54 voices, and was last updated 6 years ago by dannybgoode.
Woodburning stoves being banned?
fifeandyFree Member
Well London’s mayor seems to think so!
https://www.theguardian.com/environment/2017/sep/29/air-pollution-sadiq-khan-calls-for-ban-on-wood-burning-stovesSaxonRiderFull MemberThis actually worries me somewhat. I understand entirely the need to control air quality, but being able to build a fire in one’s own home seems a fairly primitive and fundamental right.
In the winter of 1997-98, Quebec experienced an ice storm that took out power across Montreal and beyond. And of course, being winter, thousands could have frozen to death. The houses with fire places ended up serving as safe places for many people.
I know the likelihood of the grid going down is small, but natural gas will not always be available to us, and wood – which is renewable – seems like a pretty straightforward alternative.
Couldn’t they just develop some sort of particulate filter for chimneys that would eliminate the concern with pollution?
chakapingFree Memberbeing able to build a fire in one’s own home seems a fairly primitive and fundamental right.
That’s not a view I’ve ever heard expressed in the UK before, we have had “smoke-free zones” as long as I can remember and smog used to be a massive problem before that.
We have to do whatever it takes to lower air pollution in cities like London, it’s killing people.
daernFree MemberThis is probably just an extension of the original Clean Air Act. As I understand it, it didn’t ban open fires, but regulated the types of fuel you could burn – i.e. smokeless coal – and it had a massive positive improvement on the air quality in built-up areas.
I guess it’s possible that they’ll ban all open fires, but I think it more likely that it will be a tightening of fuel types.
nedrapierFull MemberCouldn’t they just develop some sort of particulate filter for chimneys that would eliminate the concern with pollution?
Could someone a gif of Richard E. Grant shouting “scrubbers!”?
thisisnotaspoonFree MemberWhy the f*** do 16% of households in the SE have wood burning stoves?
I had one when I lived in Teesside, but that was because it was an old cottage in an old village which by SE standards was barely above a Favella and had an easy supply of wood!
I know London likes to pretend the world has come to an end every time an inch of snow causes the busses to be canceled and people walk home and everyone talks about how they talked to each other and London suddenly had this community blitz-spirit. But that’s Montreal, if you hadn’t noticed it’s in Canada which looks like this:
You’re in London which is sandwiched between Surrey which looks like this:
And Essex:
SaxonRiderFull MemberWe have to do whatever it takes to lower air pollution in cities like London, it’s killing people.
People die from ALOT of stuff. Having said that, I accept what you’re saying, and am quite environmentally concerned myself.
But I also have a bit of a libertarian streak, and would rather see technology tackle air issues that an outright ban on fires in fireplaces.
Hence my question above. Would some sort of particulate filter on chimneys not go a long way to sorting the problem? I am not a scientist, and so ask this question sincerely.
davosaurusrexFull MemberSouth Coast here, of the group I ride with 3 of 4 have wood burners and the other has open fireplaces. I do like burning stuff as much as anyone else but think they’re not necessary in this part of the world so limit my pyromania to the chiminea in the garden a few times a year
ransosFree MemberFor smoke control areas (as an example, the whole of Bristol is one) you can only use an open fire if you’re burning an approved fuel: https://smokecontrol.defra.gov.uk/fuels.php?country=england
Having said that, AFAIK there is zero enforcement.
thecaptainFree MemberI’m surprised they aren’t already banned in smoke control areas.
Filters may help but will probably reduce the draw which may cause other problems.
ransosFree MemberI’m surprised they aren’t already banned in smoke control areas.
You have to use an “exempt appliance”.
https://smokecontrol.defra.gov.uk/appliances.php?country=england
whitestoneFree MemberYou can fit particulate scrubbers to chimneys – industrial ones sometimes have them. Not cheap though and there may be a lower limit to the size, the only one I’ve seen was on the flare stack at an oil refinery!
Just how many wood burning stoves are there in London? I’d be pretty surprised if their contribution was more than 1% of that of motor vehicles.
chakapingFree MemberWhy the f*** do 16% of households in the SE have wood burning stoves?
I’d imagine it’s a mix of fashion, entitlement, ignorance and “having a strong libertarian streak” – which you can categorise as you wish.
thisisnotaspoonFree MemberHence my question above. Would some sort of particulate filter on chimneys not go a long way to sorting the problem? I am not a scientist, and so ask this question sincerely.
It would, but consider
a) how much more crap a solid fuel fire produces compared to a diesel car (back of a fag packet somewhere between 100,000% and 1,000,000% of a diesel car’s emissions). Which gives an idea of the size of filter you’d need.
b) the cost of cleaning/replacing the DPF in a carThat’s not entirely true, you’d use some sort of wet electrostatic scrubber in the flue, but then you’ve got the electrostatic generator, pumps, filters, gallons of horrible contaminated water.
n0b0dy0ftheg0atFree MemberBlaming the smog on wood burning stoves? 😆
How about blaming all the people using fossil fuel motor vehicles for journeys of convenience, that are often journeys of less than five miles and so easily ride-able by bike or other eco-friendly means, as opposed to journeys of necessity?
Local news I saw yesterday http://www.dailyecho.co.uk/news/15561891.The_new_billboard_aimed_at_shaming_Southampton_into_action/
twowheelsFree MemberThe problem of draw could be solved with fans to.pull air through.
In London I’ve found it especially bad cycling along towpaths in winter where 2-3 deep rows of boats are burning coal or wood and buildings/walls/cutting preventing smoke blowing away.
chakapingFree MemberAction needs to be taken on all fronts.
I was listening to an interesting BBC podcast on cruise liners and air pollution in Greenwich, here it is…
http://www.bbc.co.uk/programmes/b082hg9gcrazyjenkins01Full Member(sorry if already said…)
Here’s an idea, how about trying to reduce the number of fossil-fuel-burning vehicles on the roads in and around London? Maybe improve public transport? Build good infrastructure to encourage and enable walking/cycling? Incentivise the use of public transport and/or cycling through tax breaks or reduction in VAT on cycling equipment?Also, how about not building so many fe*king houses in such a small area to allow natural ventilation of the build up of smoke/fumes/exhaust?
I am CONVINCED this would have a MUCH bigger effect than stopping a bit of burning wood.
twowheelsFree Member@chakaping- yes and yearning for ye olde world charms I think.
dissonanceFull MemberHow about blaming all the people using fossil fuel motor vehicles for journeys of convenience
The London authorities have been trying to take action against those things as well.
Its just that wood burning stoves etc seem to be contributing significantly to some forms of pollution.OnzadogFree MemberI know the likelihood of the grid going down is small,
Not as small as you might hope/think.
bedmakerFull MemberI make my living installing woodburners, as well as having two in my own home, so I’m a bit biased.
But, I’d happily see them banned in cities.
Even with a Defra approved stove, the scope for end user bellendry means they can be very polluting.cheese@4pFull MemberMaybe we should find an alternative to all the “flamings” on here too?
thisisnotaspoonFree Memberthe only one I’ve seen was on the flare stack at an oil refinery!
No you didn’t (or I’d be very interested to know which one it was), they’re intentionally not fitted with any sort of filter as if they’re used it’s as a last resort and you want as little back pressure as possible post combustion.
They often do have steam injection though which reduces the production of particulates, BUT it’s at the expense of other things like HC emissions, sometimes the steam is there to keep the flow supersonic at the tip, which means even if the flame goes out it won’t burn as it mixes too well and falls below the LFL.
Usualy goes something like this:
– Something goes wrong ->big smokey flare
– Local council/regulator phones in to complain -> steam injected
– Emissions are now invisible so no one cares.ow about blaming all the people using fossil fuel motor vehicles for journeys of convenience
But as a proportion?
There are 11.2million car journeys in London every day, and ~516,000 wood burning stove households (assumed same proportion as the SE as a whole), yet the latter is apparently 25-33% of the particulate pollution.
Ban 11,200,000 journeys or 516,000 stoves (which are entirely recreational and serve no actual purpose as I bet you almost all of those stoves are in houses with gas or electric heating).
whitestoneFree MemberMight have been some form of steam injector though it was referred to as a scrubber. Installed after the village nearby complained of the “smoke” from the stack.
giantalkaliFree MemberThe problem of draw could be solved with fans to.pull air through
I’ve not heard it called that for a while, and fans sound rather ambitious. Kids these days…
trail_ratFree Membersurely in london they all have access to gas – ive never under stood it in the case if you have a gas boiler……
mean while those of us with no access to gas would be cheaper burning $10 notes in the stove to stay warm than using the oil.
and dont say move to the city as stacked livings not a good for your health either.
chiefgrooveguruFull Member1 smokeless zone approved wood burning stove generates more particulates than 1000 petrol cars.
davosaurusrexFull MemberCome to think of it one of my aforementioned mates also has a woodburner in his massive yurt! Ooooh, he’s going to burn in hell!
ransosFree MemberAction needs to be taken on all fronts.
Diesel vehicles are the dominant source of poor air quality in our cities. Put another way: poor air doesn’t go away in the summer.
thisisnotaspoonFree MemberAction needs to be taken on all fronts.
Diesel vehicles are the dominant source of poor air quality in our cities. Put another way: poor air doesn’t go away in the summer.Depends where you live, my parents village actually makes you cough in winter from all the smoke coming from the stoves. It is the absolute epitome of a middle class expensive village though, and not helped by being in a steep sided valley. IF you cycle up the hill you can actually see all the smoke coming from the chimneys and getting trapped.
Conversely I live s stone’s throw from J11 of the M4, smog isn’t a problem.
And as the stats show, if 33% of the pollution in london is coming from a very small number of stoves then it makes far more sense to ban half a million stoves and reduce it by a third than ban half a million cars and barely make a dent.
ransosFree MemberDepends where you live, my parents village actually makes you cough in winter from all the smoke coming from the stoves.
I was talking about cities, which have a significantly worse air quality problem…
And as the stats show, if 33% of the pollution is coming from a very small number of stoves then it makes far more sense to ban half a million stoves and reduce it by a third than ban half a million cars and barely make a dent.
Do they show that? And what we do about the majority of the time when people aren’t using their stoves?
chakapingFree MemberYes diesel vehicles are also a big problem in cities. I would like to see strong action on that too.
ransosFree MemberYes diesel vehicles are also a big problem in cities. I would like to see strong action on that too.
They’re the primary problem. So they’re the thing we should tackle first.
chakapingFree MemberDon’t worry, Sadiq’s already on it: https://www.london.gov.uk/press-releases/mayoral/mayor-plans-to-introduce-ulez-in-april-2019
ransosFree MemberDon’t worry, Sadiq’s already on it: https://www.london.gov.uk/press-releases/mayoral/mayor-plans-to-introduce-ulez-in-april-2019
In fairness, he is bringing in some important initiatives. Electric black cabs from Jan 18: http://news.sky.com/story/black-cabs-go-green-electric-taxis-on-the-way-11058491
thisisnotaspoonFree MemberDo they show that?
Did you actually read the article?
FTA;
It is estimated that between a quarter and a third of all of London’s fine-particle pollution comes from domestic wood burning.
Yes transport pollution is a problem, but if banning a comparatively small number of polluters has a similar impact to removing around 4,000,000 car journeys? And that’s assuming a worst case where wood burning is at the lower end of the quoted figures and transport is responsible for everything else (it’s not by a long way). So it’s probably more like 6, 7 million journeys a day.
oikeithFull MemberIn fairness, he is bringing in some important initiatives. Electric black cabs from Jan 18: http://news.sky.com/story/black-cabs-go-green-electric-taxis-on-the-way-11058491
A black cab driver commented on the Uber thread saying these new electric black cabs will cost £55k each, the existing model costs £35k. Seems like a great update at a time when black cab driver numbers are getting lower due to the competition (unfair or fair regardless) and quite a hefty wack for new drivers to pay even after the £5k grant if you fancy taking up the trade!
silvermattFree MemberDiesel vehicles are the dominant source of poor air quality in our cities. Put another way: poor air doesn’t go away in the summer.
That’s because in the summer the stove users are busy stoking their Weber smokers and adding hickory chips to their BBQs. He’s missed a trick here. Easier answer would be to ban matches and firelighters! 😆
The topic ‘Woodburning stoves being banned?’ is closed to new replies.
