Search the forum using the power of Google
Viewing 12 posts - 1 through 12 (of 12 total)
  • Small mudguard for Fox 36
  • jsync
    Hi,
    I’m after a small mudguard for a Fox 36 2018. I’ve seen this but it’s 2021 onwards so doesn’t fit.
    Mudguard
    Ideally one that doesn’t use cable ties would be great as my fork has the screw holes in the brace like the ones linked above but not the air equaliser thingys they put on from 2021. What’s everyone using? Anything similar?
    Thanks!
    singlespeedstu
    I’ve got a couple of these for 36’s of around that vintage.
    https://www.syncros.com/gb/en/product/syncros-trail-fender
    Tracey
    Syncros do one specific to the older 36s
    Can be had in black or orange
    hot_fiat
    The syncros one is really good. Strong, bolts straight on, doesn’t look like a 1970s trials motorbike fender.
    Rubber_Buccaneer
    I have two. The Syncros already mentioned is very small but good or RRP’s bolt on for something a little bigger or a lot bigger (two sizes available)
    http://www.rapidracerproducts.com/products/mudguards/proguard-bolt-on.html
    towzer
    Discrete cough, I have one (off 34 boost, black)that I don’t use, it looks very nice but the rrp large actually stops the mud.
    mrhoppy
    I’ve got the synchros one, it doesn’t look too bad but it’s just dead weight, as a mudguard it is a waste of time.
    jam-bo
    I dont really see the point in small mudguards. Fit something that works or don’t bother.
    RRP max here all year round on the front…
    DrP
    As above..
    Get a proper one (rrp) or don’t bother!
    DrP
    jsync
    Thanks guys, that gives me a couple of options. I already have a dfender which works very well but just wanted something smaller for everyday. The synchros is the size that I’m after as I can swap it when biblical. Obviously the smaller it is the less it does!
    drdexx
    For my 36 l I use an bolt on RRP mini during the nicer months to keep the little stones and splashes out of my face,does a decent job.
    When it’s truly wet and sloppy, I use a crud catcher XL, easy to put on and remove via the bands, and does a solid job.
    nwgiles
    I have the ‘long’ fox mudguard on my 36’s, its not particularly big but the front bit helps with splashes.
    I also don’t have the vents which makes it easier to fit.
    Buy the mudguard,
    then using an allen key unscrew the vent covers,
    remove the plastic spacer/ring,
    push vent covers through holes in mudguard,
    insert vent covers without spacer/ring back in hole,
    tighen,
    then insert the bolts to the back of the cross brace,
    took about 2minutes, and is super secure.
Join Singletrack From Only £12.501/2 Price Singletrack Offer
Use code HELLO54 when you join us as a print or digital member and your membership will be half price for the first year.
The Print+ membership where Singletrack magazine drops through your door, plus full digital access, is normally £45, now only £22.50 with the code. And a digital membership where you can read all the digital magazines is normally £25, and now £12.50 with the code.
Simply use code HELLO54 at checkout.
(New annually renewing membership only. Excludes Gift Memberships, Discount applies to first year. Cannot be used in conjunction with other offers, or when switching memberships)
