Viewing 14 posts - 1 through 14 (of 14 total)
  • Slipping chain??
  • My sons Whyte 629 has a slipping chain. I’ve recently changed the cassette, chain and rear deraillier. Seems to be only slipping on the outer chainring. Looking at it I think the outer chainring is worn and causing the slip.
    What do you all think?
    Premier Icon molgrips
    Member
    Those teeth have lost about 60% of the material!
    Premier Icon simondbarnes
    Subscriber
    It is. Very.
    Premier Icon bruneep
    Subscriber
    do you know jiff?
    Thanks, relatively easy job to change it?
    robo89
    Member
    Jesus christ dude, that is not only extremely worn but extremely lethal, looks sharper than half of my saws.
    That could slice open a femural artery with ease in a crash.
    damascus
    Member
    If you’ve done everything else and your doing the outer you might as well change the granny as well
    Premier Icon northernsoul
    Subscriber
    That reminds me, my eldest keeps asking if we’ll let him watch Jaws 🦈
    ogden
    Member
    Just look at the difference between the inner and outer chainring teeth!
    Will the cranks need removing to change the outer ring?
    stuey
    Member
    With that amount of wear -May need a new chain and cassette too !
    Premier Icon ocrider
    Subscriber
    It looks like he’s never used the granny ring!
    Yeah you’ll need to remove the cranks to change the chainring, but it’s gxp so you’ll only need an 8mm Allen key.
    Premier Icon sillyoldman
    Subscriber
    User name seems apt.
    robo89
    Member
    I can always get my ring off without removing my crank, it’s always worth trying first, then again if its been a while, a good inspection and re grease wouldn’t hurt.
