Just kind of asking as i’m not sure if what i was thinking was correct.
So i’ve got a Mavic Crossride 29er wheel as my mud wheel on the Parkwood. I noticed one of the spokes is a bit loose, it’s not a wheel i’ve used much as it’s lived on the turbo for 18 months.
So i decided to whip the tape off and see if i could tighten it as when i used the spoke tool it wasn’t getting any tighter. What i found was what i expected, the head in the rim is rusted and seized to the end of the spoke, so you’re only rotating the whole thing, not the nipple.
First part of the issue is that on the rim side it looks like a normal hex socket, but none of mine will fit, is there a common size ? they seem close, but i think it may be 6mm, but my 6mm is too fat to go through the rim hole.
So i was thinking the best method is to just snip the spoke and replace with a new one ? Which may in itself be an issue as they’re straight pull and i don’t think i have any straight pull spokes to hand. But that’s not impossible to resolve of course.
