about 20 odd years ago I used to work for Bosch (Who owned Skil at the time) in their lawn and garden power tools bit and yes brushes often came pre-assembled in a little Carrier to aid the line workers, the carrier would be pushed onto the motor body, then assembled into the tool and once everything was lined up, a couple of tabs pulled away to release the brushes onto the comm and avoid assembly damage. They were quite good at that sort of thing.
But I very much doubt you’ll find brush holders available to buy after market. You should be able to hunt down a pair of compatible brushes via a google search using the tool’s model number they might be labelled as being for Bosch rather than Skil.
Failing that measure up the existing brushes (carefully so as not to chip them) and you should be able to find a pair to fit….
