can anyone recommend me a single speed freehub (disk)?
I want to fit 2 wide spaced surly sprockets on back to back so i can run dingle speed. (if you run the surly sprockets built in spacers facing each other the spacing is more or less the same as the big ring to middle ring on an XT crankset.)
I guess the options are Hope, Chris King (both look lovely but very expensive) and Superstar, which is a lot cheaper. The superstar one has threads on the OD of the freehub body, which has confused me somewhat, the Hope one has them in the standard freehub ID position.
Are there any others to consider?
