Thanks folks. Useful info indeed.
SRAM Rival look like a good value option but is there a bottom bracket wear issue compared with shimano? It may be a long time ago but do I recall some problems with Truvativ/SRAM?
Middleburn with a direct mount ring has a very clean look but the cost difference is substantial. Are they shimano BB compatible? if they are then I see that as an advantage with only one BB standard in my shed.
I will probably use a narrow freehub rather than a screw-on, in which case I’ll have some chainline adjustment available to me. Probably not a full sized freehub though.
