Fitting, if you want to use something to lubricate them on it’s ime best to use nothing but isopropyl alcohol. Easiest if it’s in an aerosol, some brake cleaner like mannol is pure isopropyl. Guarantees that it evaporates away to nothing which not all gels will do. Never felt the need for hairspray, with decent grips anyway.
If you’ve got an air compressor, use that, it’s cheat mode. If you don’t, and you’re struggling, try the Cable Tie Train Tracks approach- put 3 or 4 of the widest cable ties you can find through teh grips, slide it on, it’ll go on easily as it runs on the cable ties more than the rubber. And then pull the cable ties out. This is easier if you have them smooth side to the grip!
Onzadog
There seems to be less of an issue with them slipping around carbon bars compared to the aluminium ones of yore.
This is unintuitive but they stick best on clean, smooth bars, not on rough surfaces. SO yeah best grip I’ve ever had is on simple carbon bars where they’ve not tried to make them grippy, or painted alu bars, worst has been on anodised rougher feeling alu bars and on carbon bars where they’ve added a “grip surface”.
But the ODIs grip pretty well regardless as long as it’s clean, I’ve never used any sort of adhesion adder or lockwire or anythinh with those. With the ESIs I used to add a single wrap of cloth tape (wiring loom tape some would call it) at the end of the bar, which I know contradicts what I said up above but helped to keep water and mud out and basically stabilised the whole thing a bit, and seems to be a bit “best of both worlds”. But I don’t bother now with the ODis.
