So I’ve got a pair of xt m785’s and after a year off the bike I’ve just tried giving them a bleed. Is there a trick people finally figured out to get around this as I remember it being a problem when they came out.
I tried using the cup and just flicking the lever, tapping the cable etc (lever elevated in regards to callipers and turned so parallel to ground). Also tried with a tube attached to calliper and forcing fluid through by braking.
Brakes still need almost priming before use. Goes almost to bar on the 1st pull but then fine for the 2nd? Any help is appreciated, Cheers.
