I’ve got a feeling my rear road Shimano caliper (flat mount) is on its way out with seal issues. Apart from fairly normal ish squealing in mucky weather they’ve always been fairly quiet and just strong and reliable.
The last few rides the rear brake has been making an awful noise for the first few stops – and it’s not even been wet / mucky out. I’ve tried cleaning up the pads but they weren’t even that old Tbf. I haven’t tried jamming in some kitchen towel and leaving it overnight to check for micro leaks but if this carries on its new caliper time I feel.
Had my eye on the Hope RX4 road calipers – I have flat mount rear mounts and a 160mm Shimano rotor.
Other than the Hope caliper is there anything else I need or will the existing hose / fittings fit the Hope?
The bike has 105 level brakes (flat mount rear / post mount front) with finned pads right now.
