be warned rear flat mount calipers only come with one set of bolts, though there are 3 lengths to choose from – and they aren’t cheap buying them on their own, I found this out the hard way
And, if you do need to order some, the length that they are labelled with is the thickness of the frame, where they pass through – NOT the length of the bolt itself.
This matters little, though, as you can’t fit a flat mount caliper to a post mount fork (even with an adaptor), so you will have to buy post mount. (Unless you want to buy a pair of post mount calipers and a pair of flat mount calipers, use one of each and keep the others for spares)
I do wish that, when designing frames with flat mounts, they would design a fork to go with it, instead of just using an existing post mount fork. There is at least one company that made it to my shopping list, only to be removed again, purely because of this crazy design ‘decision’.
P.S. it’s purely a cosmetic choice, but the flat mount calipers look far nicer (IMO)
