Hi, can anyone explain shimano’s latest crankset line up to me as I’m confusing myself with what I think I’m after.
What I would like is a replacement crankset (with a 34t chainring) to go onto my Chameleon when I build it back up with a new XT 1×12 groupset. I was going to try and re-use my old GX eagle crankset and chainring but decided I that it would annoy me if the parts didn’t match nicely.
The frame is set up with boost wheels and I’ve previously been running a boost GXP GX Eagle crankset/chainring combination with no issues; I think this has a chain line of 52 mm.
On shimano’s configuration compatibility checker they list the FC-M8100-1 as being compatible with a boost setup (148 mm O.L.D.) and also list the FC-M8120-1 variant as being boost compatible.
Shimano list the chainline for the M8100 as 52 mm and the M8120 as 55 mm, this would lead me to thinking that I should be fine with the M8100 as a replacement but then what is the M8120 (or indeed the M8130) for?
So, can anyone confirm that the FC-M8100-1 is likely to be a perfectly acceptable replacement for my existing boost set-up (i.e. I won’t end up jamming the shimano chainring into my frame because of clearance changes) or do I need to try and find a M8120 instead?
