Rigged up a bike with a Zee crank (which worked flawlessly with a Praxxis 10 speed and Shimano 10 speed cassettes on the same bike before) with an 11 speed 11-42 cassette, 11 speed chain, 11 speed slx shifter and single Gammut 32 chain ring which says it’s rated for 11 speed. On the 42 and next cog down there is a clacking noise and if you back pedal the chain falls off down onto a lower cog.
Just out of interest I tried doing the same thing on an 11 speed slx double equipped bike. On the granny chain ring it’s fine but on the 36 outer, back pedalling on the same two innermost cogs results in the same thing happening with the chain tumbling down onto cogs lower down.
I guess twisting the chain across like that on the 11 speed double system is asking for trouble but if you do it on 10 speed doubles it doesn’t derail.
I’m more interested in knowing what is going wrong with the zee crank. I can’t see how it can be a chain line issue but maybe it is, or I’m thinking there must be another compatibility issue and maybe you can only operate Shimano 11 speed with Shimano 11 speed specific single ring cranks. I’ll get onto Madison in the week and ask…but in the meantime….does anyone know what the problem is?
