Search the forum using the power of Google
  • This topic has 4 replies, 4 voices, and was last updated 6 years ago by Solo.
Viewing 5 posts - 1 through 5 (of 5 total)
  • Seat Ibiza – retrofitting parking sensors or camera
  • RustyMac
    My better half has a 2013 Seat Ibiza Fr which comes with the detachable Garmin navigation/media unit.
    The car has not been factory fitted with parking sensors or a reversing camera however on similar spec cars these options are available and link in with the satnav unit as a display.
    Does anyone know if a camera or parking sensors can be retrofitted and tie in with the existing car equipment rather than having additional sounders / displays.
    Is this type of thing a job solely for the main dealer or should i be looking else where?
    Rusty
    stumpy01
    I did a quick search on Seatcupra.net & it was a bit unclear. Sounds like you can fit a Cobra kit, but I wasn’t sure if this ties in with the in-car screen or not.
    A few threads mentioned the dealer doing this job for around £200-300.
    Here are the links I found anyway:
    http://www.seatcupra.net/forums/showthread.php?t=421116&highlight=retrofit+parking+sensor
    http://www.seatcupra.net/forums/showthread.php?t=418660&highlight=retrofit+parking+sensor
    http://www.seatcupra.net/forums/showthread.php?t=342385&highlight=retrofit+parking+sensor
    RustyMac
    Cheers for seaching stumpy. Seems a bit of a minefield.
    I’ll pop the dealer we bought from a email and see if they will quote me a price for installation including integration to the seat portable system head unit.
    gobuchul
    Good luck with that. I would expect something crazy like £1000+ to come back.
    There are loads of after market fitting companies, I would try that route.
    Solo
    Ime, Stumpy is on the right path.
    I’ve two VAG cars and whenever I’ve wanted to retro fit stuff, I scan the forums. Usually there’s a “how to” for the common retro fits.
    I have a VCDS cable and a copy of Elsawin, both of which are very useful.
The topic ‘Seat Ibiza – retrofitting parking sensors or camera’ is closed to new replies.
Try Singletrack For Only 99p
Or enjoy the latest magazine for only £2.99
