I’m going to be putting new hooks and shelves on my garage wall. The wall is breeze block and mortar construction, and I’ve already had a bike fall on the floor by ripping the rawlplug out so I want to do it properly this time. I’m guessing the problem was that the breeze block collapsed a bit so the plug wasn’t really biting.
What does STW endorse? Should I screw into the breeze block with a plug (being careful to make a smaller hole for the rawl plug)? Or screw directly into the block? Or screw into the mortar between the blocks instead? Using a plug, or one of those concrete screws instead? I also see hammer-in concrete fittings which seem neat, assuming I can undo them in the future.
Too many options, not enough knowledge! Any suggestions from the hive mind?
