We had some building work done in the summer of last year. Involved a scaffold roof over one side of the house while part of our roof was off.
When the scaffold was put up, there was a large bit rested between our two chimney stacks (we’re terraced) and the roof of the scaffold was then on top of that. Was braced on the front by a scaffold tower, but I don’t think it took much weight.
This winter we’ve noticed there’s damp in the room below one of the chimneys which has been traced back to a leak coming in around the chimney and running down the breast in the loft.
As far as I can tell, for at least 7 years that I’ve been there if not the 80 it’s been built, there have been no leaks.
Now, after the scaffold there are leaks most times it rains. Last weekend was a bit exceptional with the wind driving the rain directly at the chimney, but it’s been happening under normal conditions too.
So is it standard practise to mount a scaffold roof between chimneys?
Just because something didn’t happen in the past does not mean it’s not going to happen in the future. The leak could simply be from the lead cracking – nothing lasts forever.
The aluminium horizontal ladder beam sitting on the chimney brick work = no issue, it’s there as lateral support to stop frame twisting on an independent scaffold.
Most likely cause is the scaffolder snapping a roof tile when building it, or damage to the lead flashing around the chimney. Get a decent roofer to take a look, no point in persuing the scaffold company they will wash their hands of that.
p.s that’s half built right ? they should never have worked on it in that state.
