Ive been using an online SAP calculation tool provided by Knauf insulation.
http://tools.knaufinsulation.co.uk/
Its pretty good bit of kit and will populate unknown elements with reasonable assumptions based on averages.
Based on my own research, calculations and systems specifications Ive populated the model with all the design details for a barn conversion Im undertaking. I havent been over-optimistic on U-values (c. 2.0 ish for windows and 0.15-0.2 for walls (340mm brick, 100m Rockwoll, 100mm Durox, 13mm Plasterboard), floors (Screed, 100mm Insulation, concrete slab) and roof (300mm+ Rockwool + Celotex)) but the SAP rating remains stubbornly low at 66 (D).
The environmental impact rating is high (95 A) due to heating system specifications which is nice though.
If anyone here knows how SAPs are actually calculated, can they point me in the direction of which part of the SAP analysis has the greatest contribution to the score? Is it U-values? Window areas? Air circulation? etc
and is the SAP rating proportionate to area and volume or is it lower for bigger buildigs simply by virtue of size?
Also can anyone direct me to an online source of R-Values for the building materials I mention above so that I can double check my U-value calcs?
