Hi all,
So, here’s the deal, simple question actually.
Running a ’18 Yari fork, which we know has a PM 180mm brake mount.
Wanted to run a 203mm rotor for my XT brakes and after a quick check it seemed to me the correct adapter would be the Shimano SM-MA-F203P/PM. It’s sometimes described as a 203mm adapter, other times as a +23mm adapter (which seemed correct).
However, after running this setup for a couple of rides, it seems to me the caliper is spaced out too much, with the pad not correctly positioned on the rotor.
Do I have the correct setup?
Thanks in advance
