My new bike has a Sektor RL fork fitted that has the ability to run Torque Cap fitted hubs. The wheels it came with are own branded standard 15mm boost hubs, which although I know are perfectly fine to use without Torque Cap ends area PITA to fit as lining them up is an absolute bugger.
I’ve also noticed that there are a variety of converters for standard hubs, e.g. SRAM’s own, Mavic, Halo to name a few but they all seem hub specific, so does anyone produce a generic converter to fit on the sleeves that the bolt goes through?
Or will one of those above do the job?
I guess an alternative would be asking a friend to 3D print a couple of spacers to do the job as they’re not load bearing but I’d prefer proper alloy ones if possible.
Cheers.
