I’m having a play about with my suspension settings – using a ShockWiz as I’m pretty clueless on what needs tweaked. I’m needing to add some more air to the shock, remove a token and it looks like I’m needing to add 1 or 2 clicks of HSC and 3 clicks of LSC.
How may clicks does the HSC knob have? Mine seems to click after a half turn of the dial and it seems to be stiff/stuck after 2 clicks – is there more and I’m needing to give the fork another wash?
Also, when I turn the HSC dial, the LSC dial turns as well – does this turning of the LSC adjust anything or do I still need to then turn the LSC as well?
Afer the tweaks done so far (adding more air), I’m absolutely convinced my rear shock is going to need a lot more tweaking as well, but the fork does feel a bit nicer so I’m thinking this is working…but I want to make sure I’m adjusting it properly.
