Which model of airshaft did you fit? The newest ones (with the deeper piston head and a red foot nut on the end of the shaft) have a bigger negative air spring volume and would require more positive air pressure, though 20 more psi does sound like a lot.
If its the previous model airshaft (thin seal head and silver foot nut on the end of the shaft), it could be the negative and positive air chambers have not been equalised. This can be fixed by cycling the forks up and down with a bit of pressure in the positive chamber.
It could also be that there is grease covering the internal ‘dimple’ on the inside of the fork leg – this allows air between the positive and negative air chambers. If there is too much grease it won’t allow air to cross over.
