Is it possible to change 140mm pikes to 150 or 160 with a new air spring?
I have heard from multiple sources that rockshox use the same chassis for all of the pikes which makes sense.
the only niggling doubt I have is that the travel scale printed on the stanchions only covers 130mm/140mm or 150mm/160mm depending on which fork you have.
To me this suggests 2 possibilities…
1, The stanchions are only long enough for that travel range stated on the side
2, All stanchions are identical but Rockshox only print on the travel ranges most likely to be used.
Obviously I would like the answer to be 2 as this would just mean the markings on the fork would be off which I can live with.
Anybody know for sure?
