Do utility companies chat with each other about when they are digging a road up? If so, do they talk about combining efforts or how to string it out as long as possible?
Roadworks between my house and gf’s house has had roadworks from 6 (maybe 7) different companies for last year, they seem to be doing various things – power lines, fibre, phone and whatever else.
Each time the road has been dug up, it gets resurfaced for about 10 days and another set of roadworks then appear and they dig the exact same hole. This would be OK if it was once section but it is a rolling piece of work.
Last lot has almost completed and another company has appeared and started digging the same locations but further back.
This was meant to be done by Easter.
So, do the companies tried to utilise the construction to benefit them all (cost savings on construction works if only needing dug once?) or do they just plan to drag everything on indefinitely?
Curious but also uncontrollable annoyed by it! Suspect annoyance is due to delays in getting where I want to be.
