For winter I like Schwalbe G-One Speeds. They’re a bit wide at 30c, but have a good ride, fine grip and seem pretty robust. Fast enough for a medium club ride (20-21 mph average). They are based on the old Schwalbe Ones. not the newer (fragile) ones. Some have noted that the nobs wear down fast, but I have not noticed this on mine.
What they fail to tell you is that once you get a puncture, it should seal, but probably won’t hold road pressure to, say, 80 PSI. The plug tends to blow out, and then it is tyre off, add a patch inside and remount. Or just pop in a tube an leave it. That’s what my front G-One is sporting at the moment after a serious glass incident. For the rear, I just pumped it up and popped in some fresh sealant. They had not been ridden for about 8 months.
Sealant is Orange.
