Viewing 30 posts - 1 through 30 (of 30 total)
  • Road cycling base in Scotland?
  • dknwhy
    Any ideas on a good Scottish base for road cycling?
    Looking for somewhere for 5 of us to base ourselves for 4-5 days and head out on scenic 50-60 mile loops.
    Pure road only/tarmac cycle paths really as a couple of the guys only have 25mm tyres.
    Trip is planned for September.
    Also, any links to GPX routes would also be great.
    poly
    My gut feel is Stirlingshire or Perthshire – you presumably want to be able to head different places each day so you need to be at a major intersection of roads. I suspect availability of accommodation will be your limiting factor, it may be a little better in September but still not great. I guess the other consideration would be – do you drive 15-20 miles in the morning to get a better starting point on some days.
    scotroutes
    The North East too – much overlooked. You can take on some hillier days – Cabrach, Lecht etc – some interesting coastal stuff around Cullen, Pennan and lots in-between.
    Some ideas here https://www.ride-the-north.co.uk/rtn153/
    aberdeenlune
    My suggestion is Ballater. You could do a loop over Gairnshiel and the Lecht. Do a day over to Glenshee Linn O Dee. Do a Cairn O Mount day. There are also flatter options along the Dee and Don valleys.
    Roads are in better condition and it’s quieter than Stirlingshire.
    highlandman
    Dunkeld, Pitlochry, Aberfeldy, Blairgowrie & Alyth spring to mind. There’s a lot of circular routing available from all of those bases, each with a good spread of variety.
    One of my fav road days out is to circle Loch Tay on the south side from Kenmore to Killin, then up over the Lawers road to the cafe at Bridge of Balgie, descend the very quiet & scenic Glen Lyon and back to the start via Keltneyburn.
    Lots of loops available; Kirkmichael & Glen Isla can be done from Dunkeld or Pitlochry start points. Circuits of Tummel & Rannoch. It’s all good.
    franksinatra
    All great suggestions so far. If you are travelling up from down south don’t over look Borders or Dumfries and Galloway.
    I say Border because I live here and there are loads of routes I enjoy. But D&G is the most overlooked area of Scotland and if jammed full of amazing riding, but everyone just drives on past it on their way up north!
    Nobeerinthefridge
    Borders, D&G and Ayrshire all have road cycling as good as anything in the north IMO.
    http://www.ayrshirealps.org/piste/
    Yetiman
    Tour of Britain will be visiting the North East in September so if you time it right you could ride part of the stage and watch it.
    https://www.tourofbritain.co.uk/stages/stage-eight/
    swavis
    scotroutes
    Agree with scotroutes here, some great wee roads about and reasonably quiet too. I must do more myself…
    Merak
    I’d echo southwest Scotland. Some great riding there and quiet wee roads too.
    joshvegas
    yep totally agree. I also agree with most of the other comments to be fair
    Robz
    As mentioned above I would suggest Aboyne or Ballater in the NE – access to Donside and Deeside – some fantastic quiet (and less quiet) roads and climbs.
    Also another vote for Pitlochry area – load of great routes round the various local lochs and glens and can access Deeside too.
    intheborders
    +1 Borders plus loads of gravel for those who’d fancy an ‘away’ day.
    trail_rat
    Pitlochry would be my vote. Get to do several iconic climbs from there as a base on both sides of the a9
    tomd
    Mine too. I think the variety you can get from there is hard to beat. Also not as bad a drive and reasonable choice of facilities as well if you want to do stuff other than cycle.
    Borders, D&G etc all great but I think if you’re coming from down south Pitlochry area will give you something very different to enjoy.
    Although the NE is considerable drier if that matters.
    scotroutes
    I was also thinking that the NE might be easier for finding accommodation.
    paton
    highlandman
    Local intel suggests that east of the Spey and north of the Gorms has much more accommodation available than further south or west, so if you cannot find anything in the more obvious places further south, I’d then think of going with Scotroutes’ suggestions.
    Waderider
    Having cycled in most parts of Scotland and lived in many parts, I reckon the best road cycling is in the SW. I’ve always liked Moniaive so that’s my suggestion for a base.
    Oblongbob
    Pitlochry was my immediate thought as a great hub for routes east and west.
    vmgscot
    D&G and Borders – less hours spent in the car getting here.
    YoKaiser
    As much as the Borders, Dumfries and Galloway, Ayrshire has some cracking roads if you are after the Scotland factor then I’d say go further north. Travelling time will be longer and if you are on the west or anywhere near the nc500 then it might be busy traffic wise, north east does seem to tackle some of this mind you. A half way house could be Dunoon, plenty accommodation, loads of quietish roads, chance for a bit of island hopping, scenery pretty good (has the lochs and mountain factor), reasonable travel links.
    epicyclo
    Inverness. Job done.
    oldtennisshoes
    Some good suggestions, but as a bit of a left field option I’d go for Blairgowrie. Excellent options in all directions.
    vmgscot
    Add a daytrip on the ferry to Arran if you want the “Scotland Factor” added to D&G/Borders base 🙂
    dknwhy
    Thanks to everyone for the advice. I’ve floated the ideas with the guys and the general consensus is that we’ll aim for something around the Pitlochry area to give access to east and west of the A9 and cut down on travel time north.
    A few of us with gravel bikes are keen to do more in the Inverness area/island hopping at a later date as part of a different trip, which will hopefully be a bit more leisurely.
    Once again, thanks for all the ideas. Pics to follow!
    dknwhy
    Bit of thread resurrection here. We’re off next week.
    Have got a lodge in Blair Atholl booked and have mapped out a couple of routes – mainly west and south west of Blair Atholl with one to the east from Kirkmichael.
    Any other areas to target or gems not to miss?
    Was looking at one way routes with train options to return but Scotrail is impossible to book bikes onto, especially as there will be 6 of us.
    Even something simple like a direct route up to Aviemore and train return or vice versa seems impossible.
    scotroutes
    https://www.highlandyaks.com/biking-shuttles-and-transport/ as a possible shuttle option.
    Don’t miss the road from Trinafour over to the A9.
    intheborders
    We were in Balir Atholl last week, the quality of the fish & chips by the pub is superb and also the Loft restaurant was really good quality.
    matt_outandabout
    Agreed.
    There are a few routes around from Blair Atholl – Rannoch – Loch Tay – Glen Lyon that are superb, and you won’t be upset about covering a couple of the sections twice on different days or directions.
    We are currently exploring all the lanes west and south of Perth – some really good quality days out between Perth, Crieff, Comrie, Auchterader and Yetts O’ Muckart
The topic ‘Road cycling base in Scotland?’ is closed to new replies.
