Am sure it’s the front end… As I only notice it at very low gears when pushing hard… I can’t replicate it at speed pushing hard. (As I will shortly be heading to the alps where this is what I will be spending long periods doing, I need to find a resolution…
so far i have:
had the headset stripped, cleaned and reinstalled nicely
swapped pedals… just in case
stripped stem and removed, cleaned and degreased bolts before reinstalling with carbon paste
done same with seatpost
I dont really have what it takes to get amongst the press fit BB myself
So final option before LBS is to get the hoods off, and clean / grease all bolts and cable clamps before re-clamping. Would almost certainly need new bar tape, so before I take the plunge, has anyone else solved annoying creaks this way?
Thanks
