Viewing 4 posts - 1 through 4 (of 4 total)
  • Rival AXS chainset – converting from 2x to 1x
  • johnny63
    Hi all,
    Would like to convert a Rival AXS chainset from 2x to 1x – is this just a straightforward case of removing the 2 and fitting the 1 ?
    Spoke to Garbaruk and they say this will work
    https://www.garbaruk.com/shop/product/107-bcd-oval.html?category=6
    But just want to make sure before ordering.
    And if it does work, then anything else I need ?
    TIA
    footflaps
    The chainline is unlikely to be as good as with a 1x chainset as the two chainrings are offset from the ideal 1x position.
    phil5556
    Does anything else use 107BCD chainrings? Why is there yet another size? I’ve just had a clear out and have found 94, 96, 104 and 110 all on the shelf 🙄
    Sorry that’s not answering your query obviously.
    johnny63
    Emailed SRAM just to check and unfortunately can’t be done as it’s a fixed spider – so will have to find a 1x crankset
    Thanks for the replies all the same
Thanks for popping by - why not stay a while?IT'S FREE
Sign up as a Singletrack Member and you can leave comments on stories, use the classified ads, and post in our forums, do quizzes and more.
Join us, join in, it’s free, and fun.
