• This topic has 4 replies, 3 voices, and was last updated 1 year ago by P20.
Viewing 5 posts - 1 through 5 (of 5 total)
  • Reverb ~ What length travel do I have? Help!!
  • Premier Icon P20
    My reverb seatpost died at the weekend. Inch of vertical play and wouldn’t rise under its own pressure. So I’ve stripped it down and gone to put it back together but can’t remember if it’s a 100mm or 125mm post for seating the IFP.  (We have 4 reverbs in my defence)
    Any easy way of telling? It’s an A1/2 model, 420mm.
    Premier Icon philjunior
    I’ve a 100mm and a 125mm, IIRC there’s a spacer in the 100mm that’s not in the 125. Might be interchangeable?
    Sorry vagueness not much help.
    Premier Icon P20
    Thanks! It’s the spacer that’s identifies it as a 100mm post
    Premier Icon gravesendgrunt
    Careful with that-my 30.9 125mm also has a bottom out spacer. Maybe a more reliable to measure inner shaft movement.
    Premier Icon P20
    Hmmmm, any idea how long the shaft is?
