My advice would be…
Measure your current bike from middle of the BB to saddle rails at max height you ever run it. Subtract from this the seatube size of the new bike. That gives you the effective seatpost exposed on the new bike once set to your height.
Subtract from this 80mm. That is a combination of 65mm allowed for the reverb post collar and head, plus 15mm leeway. You want some manual height adjustment in a reverb in my opinion. Running it slammed onto the seat clamp is not a good idea for all possible conditions/rides.
Then, buy the biggest post that is shorter than the number you’re left with. If its 137 then get a 125, 164 get a 150 etc…. If its say 148 then a 150 would be viable, you’ll only have 13mm of ‘room’, not the 15mm I suggested, so obviously application of common sense applies too….
I can feel a ‘reverb size suggester widget’ coming on for our website….
